Den Explorer I zum Müllfahrzeug umgebaut
--> Monster Garage1994 Ford Explorer (Eddie Bauer edition) Specs
• 4.0-liter V-6 engine
• 210 horsepower
• automatic transmission
• rear-wheel drive
• "Eddie Bauer" interior trim and exterior paint
Monster Machine Specs
• customized hydraulically powered metal arm
• hydraulic garbage-crusher
• hydraulic roof-lifter
• KMC wheels
• House of Kolor paint
Transition Technique
Garbage equipment and storage take space, so the team started their transformation by pulling out the Explorer's back seat. They then installed a customized hydraulically powered metal arm (designed and redesigned many, many times) to grab garbage cans and empty them into a receptacle that included a hydraulic crusher to compact the trash. Cutting the roof, they fitted it with a hinge and a hydraulic system to lift it up, creating room for the arm to pick up cans and dump their trash.
Its mechanical metamorphosis complete, the Explorer was turned over for its external makeover, beginning with a primer sealer coat and white base coat. Two coats of ice-white pearl were added, and a silver base coat followed. Then silver metal-flake flames were applied to the vehicle, and a final clear coat of paint. KMC wheels rounded out the package.
If you thought your garbage cans were in danger before, you should see them being picked up by this monster machine.
Ein Explorer ist sich doch für nix zu fein ........
"Monster Garage" läuft regelmäßig auf D-MAX.
Manchmal werden da recht pfiffige Sachen zusammengeschraubt.
